The filter is not full flow, it has a restrictor in the bolt (IIRC) that allows modest amounts of oil to bleed into the filter then back into the block through the filter boss base. If the metering hole is wrong, or out of place there is the problem. If you are sure the pressure regulators are working, and the filter orifice is OK (checked from outside) I would pull the pan, put a laundry tub under the engine, and pressurize the system from the oil pressure sending unit threaded hole. Using just a hand pumped oil can, may work. Look for hemorrhaging in the galleries and from the filter housing. return. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
