Re: Need help fixing carb for 1952 H
Posted by Bob M on May 27, 2012 at 10:13:08 from (74.67.189.51):
In Reply to: Need help fixing carb for 1952 H posted by dstates on May 27, 2012 at 09:54:46:
That busted part is the "venturi". It's cast out of pot metal (zinc); is somewhat delicate as you discovered!
The venturi is supposed to slip fit into the body casting. Most likely rust/gum has stuck it hard in the casting. Heating lightly and tapping with a hammer should free it up.
A tractor boneyard is probably your best source for a replacement venturi, or a complete replacement carb. (Judging from your photos your carb may have other issues from internal corrosion...)
