Re: Farmall 400 burning up points
Posted by Theron Dickinson on May 27, 2012 at 11:51:53 from (184.8.142.249):
In Reply to: Farmall 400 burning up points posted by Theron Dickinson on May 25, 2012 at 20:22:55:
The tractor is running fine now. I put a resistor in between the ignition switch and the negative side of the coil. I put another new coil on it, the coil is a 12 volt that says on the side requires external resistor. i put a spark plug wires on it. I replaced the condenser, points which i gaped to .022, rotor, cap, and spark plugs. I also put a new wire from the positive side of the coil to distributor. Thanks for the help
Its a learning experience i never worked on gas tractor before.
