Re: Verifying reversed polarity
Posted by old on May 27, 2012 at 15:56:40 from (209.86.226.32):
In Reply to: Verifying reversed polarity posted by LRRifleman on May 27, 2012 at 15:12:56:
The starter does not care if it is + or - ground and a 6 volt starter will work on 12 volts as long as you do not hold it in the start position for a long time. I have a 340 here that I converted to 12 volts and it still has the old starter on it and a Delco 10si alternator on it which is also easy to wire up.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
