Re: Darn B generator problem still
Posted by Janicholson on May 27, 2012 at 16:52:02 from (96.24.99.126):
In Reply to: Re: Darn B generator problem still posted by luv2wrench on May 27, 2012 at 14:56:42:
third party image
The switch for the lights controls the charge rate. If the switch is grounded well on H it should charge OK with the lights on (maybe 3 0r 4 amps.) The wire from the switch must be from the correct terminal. It should be the terminal that is fully grounded when on H charge, or D or B, and with the resistor (not the light resistor) in the circuit when on the L position (about 2 to 3 ohms)
To see if it will charge correctly with the lights on, run it at 3/4 throttle, turn on the lights and ground the F terminal on the gen. If it now charges enough (7volts or a bit more) the switch is not going to full ground (possible wrong terminal)
