Re: B from 113 to 135 ci
Posted by CNKS on May 27, 2012 at 17:47:59 from (216.144.104.128):
In Reply to: B from 113 to 135 ci posted by Morris Krodle on May 27, 2012 at 14:42:48:
If the engine is original it can be converted to 123 inches by using thinner sleeves. To be 135 cu in it has to be bored, the later Super A and Super C could be converted to 135 without boring. To do that without boring your block number must be 354894, if original it will not be that number. Simpler to go to 123, every thing else fits, you won't get that much more power with 135, you can increase the HP with step head pistons. Engine kits to do that are available from this site and Bates Corp, etc. In the last couple of years my 113 Super A and C were converted to 135 and 123 cu in, respectively.
