Re: H4 magneto shorting
Posted by pete 23 on May 27, 2012 at 20:52:41 from (74.32.229.231):
In Reply to: H4 magneto shorting posted by sven on May 27, 2012 at 19:58:08:
I think you have the rotor internal timeing wrong, therefore the rotor is not aligned with the terminal inside the dist cap. The gap between rotor tip and cap is apparently wider than the path the coil is taking to ground. There is a mark L & R on rotor, notch on little gear. Align the R with the notch. At any rate, the spark is taking the easier route, might be a open coil to cap wire also.
