Posted by sflem849 on May 28, 2012 at 04:24:55 from (69.197.84.39):
In Reply to: help 650 diesel posted by TedinNE on May 27, 2012 at 20:16:13:
TedinNE said: (quoted from post at 20:16:13 05/27/12) My first thought would be you have a starting valve stuck open on #3. Quick check leave the change over lever on diesel & crank it over with the starter. Will be able to hear the difference when #3 comes up on compression, will turn over easier.Could also remove #3 spark plug , should not get compression out the plug hole on diesel. Can remove the valve cover & rocker arms and free up the valve.
Good call. Wouldn't the plug be pretty fuel covered and nasty if that was going on?
That would also explain nasty white smoke when running on gas. That cylinder is probably loaded with diesel.
This post was edited by sflem849 at 04:25:57 05/28/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
