Re: What to use to get rid of rust in cooling system?
Posted by John G. Hasler on May 28, 2012 at 06:07:05 from (174.124.47.216):
In Reply to: What to use to get rid of rust in cooling system? posted by bb in ok on May 27, 2012 at 22:35:59:
> A mechanic told me to use like liquid plummer
> and make sure to get it all flushed out but I
> am not sure about that one.
That's acid. It's ok to use acid to clean a block (I use dairy pipeline cleaner: phosphoric acid) but if you get it in your radiator you'll have leaks for sure.
I'd follow JRSutton's advice. You're lucky to just have rust. We have hard water so every block is full of limestone.
