Re: Darn B generator problem still
Posted by pete 23 on May 28, 2012 at 12:39:50 from (74.32.229.231):
In Reply to: Darn B generator problem still posted by luv2wrench on May 27, 2012 at 13:24:44:
If it charges like you indicated when you ground the field that proves you have a grounding problem (or poor wire from field to switch) at the switch. I like to run a separate ground wire from the light switch back to the generator mount. That eleminates all rusted connections at light switch mounting, box , and brackets.
