Re: Hydro foot-n-inch pedal adjustment
Posted by pete 23 on May 28, 2012 at 12:48:12 from (74.32.229.231):
In Reply to: Hydro foot-n-inch pedal adjustment posted by Steve656 on May 28, 2012 at 12:37:08:
Pretty simple, just make sure the pedal does not
contact the platform. If it did that would keep
valve from fully seating internally. If you are
having some problems with it you probably have a
broken spring inside or if it returns too slowly,
the fluid has leaked to the back side of the
dashpot piston. In that case I just loosen the two
little bolts and let that trapped fluid leak
out and tighten back down. Originally they were
filled with kerosene in there to make pedal
return slowly (but not too slow) but still work in
cold weather.
