Thanks Pete22...long story short I have been on here before about this Hydro slipping in high range. With with advice from here I found if I pulled up on the pedal while doing the stall test it would stall the engine. Now mind you it could only be pulled up VERY littel. Looking it over I see there is an adjustment on the valve. I will have to play with it and make it so the pedal does not contact the shelve at all. Another thing..I had a spot on a small hill that I discovered this "slipping" problem. took it to the hill and sure enuff it still slipped when start up a rather steep grade (runs fine on the road when it is already rolling going up small grades) I reached down and pulled up on the pedal and it loaded the engine more but still "slipped". I am thinking adjusting it properly may resolve the problem??? When IO get home tomorrow I will give it a try. Thanks for any and all help or suggestions.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
