Re: Carb trouble
Posted by old on May 28, 2012 at 20:05:35 from (209.86.226.27):
In Reply to: Re: Carb trouble posted by NationalHarvester460hi on May 28, 2012 at 19:57:52:
I can not say about a carb with that solenoid since I have not messed with ones with them. Another thing to check is pull the air cleaner tube off and hold your hand over the carb and crank the engine over. You should fell a good bit of suction and if you do not then you may have a manifold gasket problem or low compression
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
