Re: 706 farmall lp
Posted by John A. on May 28, 2012 at 20:48:33 from (76.1.122.180):
In Reply to: 706 farmall lp posted by chris cummins on May 28, 2012 at 13:44:34:
Chris, SAVE IT !!!!!!!
Just Saved a 656 LP from the Crushers about 2 months ago. Last week ordered all 4 replacement parts for the LP tank about $95 all total! "Liquid, Vapor, Liquid Fill, Vapor return"
The engine wasn't stuck, dropped the pan, cleaned out the nasty oil & residue, and cleaned the oil screen assembly, Plugs, wires, cap, points, condenser, fresh oil, and filter, It will run on gas, will get tank filled later this week and we will go from there.
Save it, At one time 706 LPs were about as numerous as hair on a dogs back here in Texas.
Call me and I will visit with you about it if you like, My # is (512) 577-3837.
Later,
John A.
