Super C hydraulic relief valve value?
Posted by NoNewParts on May 29, 2012 at 03:21:25 from (67.240.145.25):
Anybody know the relief valve pressure value
on a Super C touch control?
You can save me a lot of searching and/or testing.
adding a remote valve and cylinder, and
eventually will bypass the touch control completely,
and just use it as a reservoir.
I'm concerned that the remote valves 1500psi minimum
relief valve setting is too high
for the stock pump.
thanks
