Re: Farmall H info
Posted by D Slater on May 29, 2012 at 03:34:03 from (184.15.45.229):
In Reply to: Re: Farmall H info posted by jal-SD on May 28, 2012 at 18:57:48:
Until the middle of 1941 H and M tractors used bull pinion gears with a keyway to keeep brake drum from spinning on the shaft. Add on disc brake attachment only worked on the splined bull gear pinion shafts. Early keyed shafts required a change to later splined type use the attachment. This makes me think if the attachment was made starting in 1940 some attachments would be made to fit the keyed shafts. Think the attachment to install on H tractors may have started around 10 to 11 years later than 1940.
