Re: shifting question
Posted by rustyfarmall on May 29, 2012 at 08:15:43 from (67.55.162.174):
In Reply to: shifting question posted by BigTone on May 29, 2012 at 07:45:50:
The "double clutching" method usually works when going from 4th into 5th.
Push the clutch pedal down, shift into neutral, let the clutch pedal up, push the pedal back down and shift into 5th. Works the same way when downshifting from 5th to 4th if needed on a steep hill.
No real need to "shift on the go" in any of the other gears. Just choose the gear needed and start out in that gear.
If you attend any tractor shows, find an old-timer to demonstrate the double clutching method.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
