Re: welding farmall sheet metal
Posted by Brownie 450 on May 29, 2012 at 09:49:02 from (66.43.241.198):
In Reply to: welding farmall sheet metal posted by mkirsch on May 29, 2012 at 07:39:29:
If it is cracks you are going after, use brazing. The stick welder will tend to melt out the sides of the cracks. Also will tend to leave the surface wavy after it cools.
If you do use stick, weld an inch & let it cool--then another inch.
