Re: Plow hook-ups
Posted by Lmack on May 29, 2012 at 14:01:42 from (24.131.58.167):
In Reply to: Plow hook-ups posted by Joshua Rod on May 29, 2012 at 10:27:40:
There is a mounted plow especially for the SC without fast hitch. That is the best set up. The plows are usually two 14's mounted directly to the axles with brackets. You will get mixed response about power needed to pull the plows. In heavy clay or Midwestern silt loam it may load the SC down in first or second gear. In the deep south coastal plain we had a sandy loam soil and we pulled two mounted 14's in third gear with both a C and a 200 (and a Jubilee and 640 Ford).
