Re: welding farmall sheet metal
Posted by Lmack on May 29, 2012 at 14:16:29 from (24.131.58.167):
In Reply to: welding farmall sheet metal posted by mkirsch on May 29, 2012 at 07:39:29:
I always use brazing for this thin stuff because I only have a stick welder. Even so I would not start with a 6011 rod but would consider a drag rod like a 6014 and no more than 3/32". The 6014 rod is not nearly as hot as the 6011 rod. Set the welder as cold as possible. The drag rod will require that you do some grinding when you are finished but the burn holes will be less. Personally I would gas weld or braze as others have suggested. Gas welding or Tig is what the body shops will do.
