Injection pump has built in excess fuel cylinder, but throttle must be set at least 1/3 or more for excess fuel feature to work. Can check with top cover off, should see stop plate move rearward when engine starts and oil pressure comes up, moves forward with no oil pressure. Not common but may be stuck rearward causing hard starting. If it is working OK then hydraulic head is probably worn enough internally that low speed cranking delivery is no longer enough to start engine when hot, but may start when fuel is cold. When it gets bad enough it will never start on it's own but only with a shot of ether but will run once it is started.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
