Farmall cub engine rebuild ridge reamer
Posted by farmallboy15 on May 29, 2012 at 15:52:36 from (184.20.168.81):
Does anyone know where to find a ridge remear small enough to fit a cub bore? about 2 5/8". Also is there anything i should watch out for during the rebuild? How do i prime the oil pump and also are there any bolts for the clutch or anything when spltting or is it just on a shaft (After the engine bolts to the clutch housing are removed can i just slide the engine out)?
