You dont need the diode with a Magneto, it dont use battery power and has no battery powered coil that could get backfed like a coil distributor ignition...
You dont need the diode with a One Wire Alternator, its to prevent battery powered coil ignition back feed run on in three wire set ups
The alternators output wires to the LOAD (NOT battery/starter) side of the ammeter. Thats the same terminal that feeds hot battery voltage to loads like lights etc. The ammeters other SUPPLY terminal has but one wire that leads to the battery often where the big battery cable atatches to starter.
The alternators has its own diode backfeed prevention so the batery dotn run down when shes setting
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
