Re: welding farmall sheet metal
Posted by Frank Caldwell on May 29, 2012 at 18:47:14 from (97.85.199.38):
In Reply to: welding farmall sheet metal posted by mkirsch on May 29, 2012 at 07:39:29:
Do you have access to a DC welder? DC+ works best on light metal. The current flows from the base metal into the electrode in DC+. With DC-, the current goes from the electrode to the base metal (this would cause the weld to "blow" holes easier. It is also used for cutting). Therefore, DC+ works best with light metal, because it is lest likely to "blow" holes. Also, use a 3/32, 6013 rod at as low an amperage as you can weld without sticking real bad. 6013 is considered a sheet metal electrode.
