Re: FARMALL B GENERATOR
Posted by luv2wrench on May 29, 2012 at 19:12:30 from (75.221.49.40):
In Reply to: Re: FARMALL B GENERATOR posted by Janicholson on May 29, 2012 at 19:01:13:
i understand all that. lights very very dim on low AND SMOKE ROLLS OUTTA the resistor coil. then lights on high work fine. what is causing that??? should i just remove resistor coil and go directly to B terminal (#3 in your pic)?????
