Re: 300 utility valve adjustment
Posted by CoopertownBob on May 29, 2012 at 21:13:02 from (74.51.5.44):
In Reply to: 300 utility valve adjustment posted by IHCPloughman on May 29, 2012 at 18:21:07:
The 300 U is only a four banger! :P
The other way to do it is to find TDC on number one, set both valves, then rotate the engine 180 degrees, set the both valves on the next cylinder in the firing order, that is number 3, then rotate 180, set both valves on number 4, then 180 once more and set both on number 2. This method is easiest if you have a hand crank to turn the engine with. If the engine will run, warm it up before the first try, then re-warm engine and check all valves again. You might be surprised how far off a few will be after setting them the first time!
