Re: Old C motor siezed
Posted by CNKS on May 30, 2012 at 05:50:37 from (216.144.104.128):
In Reply to: Old C motor siezed posted by David Ohio on May 30, 2012 at 02:49:16:
Those are wet sleeves, unless you have extreme rust between the sleeve and the bore, the only thing holding them in is an oring at the bottom of the sleeve. You should be able to drive the sleeve piston and rod out as a unit.
