Posted by mkirsch on May 30, 2012 at 05:55:22 from (64.80.110.74):
In Reply to: H Questions posted by BruceS. on May 29, 2012 at 14:52:58:
The serial number issue may have been covered, but I'm pretty sure the information is inaccurate.
The only time the chassis serial number and engine serial number matched is early on in production, if then. Like maybe 1939 through 1940 or so.
These engines were used in H's, W4's, and power units IIRC. Some were held back as replacement parts. Engines had a different serial number sequence from the tractors.
100,000 off probably means it's a replacement engine, but the point here is the serial numbers probably will NOT match.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
