Posted by old on May 30, 2012 at 15:43:04 from (209.86.226.34):
In Reply to: stuck clutch posted by Phil Tibbetts on May 30, 2012 at 15:04:03:
There are a number of ways that might work. Blocking the clutch pedal down for a few days may do it. Or drive it around in the highest gear you can safely do so in since the higher the gear the more pull is put on the clutch so more likely to free up sooner. Then if you can also add some sort of load to it that helps more. BUT only do the driving thing if you can do so in a safe way because you will not be able to stop it till the clutch frees up so you could run something over that you do not want to run over. You can also pull the starter off and then spray brake cleaner spray on the clutch which may also free it up
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
