Re: farmall 140 leaking water
Posted by Jim Becker on May 30, 2012 at 21:26:23 from (173.74.120.222):
In Reply to: farmall 140 leaking water posted by ep1522 on May 30, 2012 at 18:41:07:
Yeah, soft plug on the back of the block.
Split the tractor at the bell housing/engine, pull the clutch and flywheel. You will then see 2 soft plugs. The smaller one is at the end of the camshaft and isn't the problem. The larger one goes into the water jacket. Pop it out, clean up a bit, pop the new one in.
