Re: Super C gov. linkage binding after new manifold
Posted by Brownie 450 on May 31, 2012 at 13:16:59 from (66.43.241.198):
In Reply to: Super C gov. linkage binding after new manifold posted by Beninarkansas on May 31, 2012 at 07:40:01:
Can you turn the throttle rod over to gain clearance? If you have the outer "elbow" of the rod against the block, try grinding some off of the curve of the bend. Last suggestion---make the holes in the new manifold oblong away from the block to gain clearance. I forget if the bolts thread in the manifold--I believe they do---use bolts in the oblong holes.
