Re: farmall B carb adjustment.
Posted by old on May 31, 2012 at 17:43:58 from (209.86.226.32):
In Reply to: farmall B carb adjustment. posted by luv2wrench on May 31, 2012 at 16:01:13:
Does your carb have the adjustment screw that sits low on the bowl or is your the type that has a plug in that area?? If the adjustment your messing with sits high on the carb just under the mount area that will not help you any that is the idle adjustment screw. If yours has that plug it means you got some dirt/rust clogging up the main jet and you need to clean the carb and maybe even put a kit in it
