Re: IH Tractor Identification
Posted by D Slater on May 31, 2012 at 18:04:19 from (184.15.46.8):
In Reply to: Re: IH Tractor Identification posted by ATF-110 on May 31, 2012 at 10:17:13:
Looked at my own list but you can find the monthly beggining serial numbers for tractors and engines by searching for wisconsin historical society. Then search there for international harvester co. serial number list. Find the one for farmall works then the year 55 and 56.
Figure out the month the serial numbers fall between. Example first built I-300 may 56 is 29610 and the first serial for june is 30544. First engine # for may is 58802, first for june is 60306. If I didn't mess up the numbers you have fall between the above. Also the serial number you have is higher than 350 tractors went.
