Re: farmall B carb adjustment.
Posted by Lmack on May 31, 2012 at 19:30:43 from (24.131.58.167):
In Reply to: Re: farmall B carb adjustment. posted by luv2wrench on May 31, 2012 at 17:29:52:
You are running lean under load. Question, do you have a fuel filter in the fuel line? If yes get rid of it you do not need it and the carburetor will not function properly with it in place. It can make the carburetor run lean under load. Make sure the fuel line is clear as well as the screen on the inlet to the carburetor. Drain both the carburetor bowl and the glass bowl under the fuel tank. If the tractor has not been run much lately, you need to run it. If the fuel is old you might have to drain the carburetor bowl several times until you run about one or two tanks of gasoline through the engine. It is a routine we went through every spring with our 200 back in the day. If this does not work you may have a vacuum leak in the intake manifold.
