Re: C301 vs. C263
Posted by Redroundhead on May 31, 2012 at 20:34:31 from (184.227.58.44):
In Reply to: C301 vs. C263 posted by 706 SS on May 31, 2012 at 09:43:38:
I would stay with the 263; it should use less fuel than the 301, and the 263 has sleeves, whereas the 301 is non sleeved, if I remember correctly. I could be wrong. I think they made a 263 sleeveless also,but not in the tractors.
Give it a good tune-up; either way you are going to use at least 5 gallons and hour doing any kind of work, and 2 gallons an hour just idling!
Good luck!
