Re: Super H differential
Posted by CoopertownBob on May 31, 2012 at 20:55:51 from (74.51.5.44):
In Reply to: Super H differential posted by rule on May 30, 2012 at 17:23:40:
SH in Ks said: (quoted from post at 20:23:40 05/30/12) I recently purchased a 53 super H and I later saw that it had a small patch bolted to the right bottom of the differential housing. The patch is 6-8 inches long and maybe 4 inches wide.
I know that sometimes a bearing can go out and the gear will push one of the balls through the housing.
Did IH ever make such a patch to cover such a hole? This patch is perfectly formed and looks too perfect to be home made.
If the owner took it to a metal fabrication shop, they could have rolled a patch to match the curve of the housing pretty easily.
On the other hand, never underestimate the ingenuity and craftsmanship of some of the older generation.
This post was edited by CoopertownBob at 20:57:16 05/31/12.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
