Re: farmall B carb adjustment.
Posted by gene bender on June 01, 2012 at 01:56:10 from (67.55.226.143):
In Reply to: farmall B carb adjustment. posted by luv2wrench on May 31, 2012 at 16:01:13:
Does your carb have the adjustable jet in the lower bowl facing the generator if not there are no adjustments to solve the problem other two screws are for idle mixture and idle speed screw on the main shaft next to the block.
