Re: 30w or 20w question
Posted by soundguy on June 01, 2012 at 18:57:34 from (184.246.66.45):
In Reply to: 30w or 20w question posted by BigTone on June 01, 2012 at 17:57:51:
i run 15w40 in all my tractors except 1 gasser I rebuilt the top end on.. I'm trying synthetic in it after sticky valves and bent pushrods..e tc..
15w40 gives you a good temp range.. and is decent oil.. more zddp than a S only rated oil.. good for flat tappets...
soundguy
