Re: Re: Re: Re: Re: Re: Re: Farmall H Electrical System
Posted by ltf in nc on September 27, 2000 at 10:03:30 from (206.228.214.246):
In Reply to: Re: Re: Re: Re: Re: Re: Farmall H Electrical System posted by Andy Martin on September 26, 2000 at 20:32:05:
The speed that the starter turns with 6 or 12 volts is based on load. With the varying loads calculated into the design the starter is designed to turn the engine at approx. 100 rpm cranking speed. The back EMF (electo motive force) which is generated by the starter as it is driven is used to control the speed of the starter. Since the 6 volt starter was designed for 6 volts and is being used w/o modification in a 12 volt system the back EMF is not to the original design and this is why the starter turns at a different speed. The load may/will vary due to the speed of rotation but it is not significant.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Re: Farmall H Electrical System
