Posted by pete 23 on June 01, 2012 at 20:28:04 from (74.32.229.231):
In Reply to: 706 timing on a 282 posted by steve in wi on June 01, 2012 at 19:22:36:
Question, what book tells you to use a timing light on a D-282 that uses a Roosa Master injection pump. Static timing is 1 degree btdc and you set speed advance to start advancing at approx 1000 rpm and be fully advanced three degrees, ( 1 1/2 marks) at approx 1700 rpm using the timing window. That gives you a total of 6 degrees of advance on the engine. A Roosa Master is inlet metered , constant ending of inj pump therefore the beginning of injection varies with amount of fuel injected for speed and load. You may well be aware of this but just thought I would throw it out there. I don't have a book in front of me so I might be off some on the rpms but not too far .
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
