Re: 706 timing on a 282
Posted by Owen Aaland on June 01, 2012 at 22:07:25 from (216.47.35.43):
In Reply to: 706 timing on a 282 posted by steve in wi on June 01, 2012 at 19:22:36:
I'm thinking that the timing specs are going to way off using a timing light on a D282 diesel. I believe that your light is going to fire at the beginning of injection where as the Roosa Master pumps are timed at the end of injection. Using the light you would need to be in the 15° - 20° BTDC instead of 3° BTDC.
