Re: oil for a belly pump?
Posted by Zachary Hoyt on June 02, 2012 at 04:43:23 from (173.84.185.1):
In Reply to: oil for a belly pump? posted by BigTone on June 01, 2012 at 18:55:17:
I had 30 wt in my H and then switched to hytran to run the haybine. Hytran is a little cheaper and is more universal to mix with other hydraulic systems.
Zach
