Re: 10-20 Magneto Update - Advice Needed
Posted by El Toro on June 02, 2012 at 07:42:28 from (108.3.225.57):
In Reply to: 10-20 Magneto Update - Advice Needed posted by Paul in CT on June 01, 2012 at 13:24:23:
You may need to bring No1 piston to TDC on the compression stroke. Once you have No1 piston at TDC look to see where your rotor is pointing.
It should be at the No1 plug tower. If it's off
you need to pull the mag and rotate the rotor so it's pointing to the No1 plug tower then reinstall the mag. Hal
