Re: Farmall A - To Buy or Not to Buy?
Posted by Heat Houser on June 02, 2012 at 11:34:00 from (69.66.35.73):
In Reply to: Farmall A - To Buy or Not to Buy? posted by SadFarmall on June 02, 2012 at 04:22:53:
I have pulled a 4 section peg harrow with my B, my father used it to pull a grain binder (bull wheel type, not PTO), and I use it to pull a 10 ft grain drill. I also use a 27V sickle bar mower and an IH side delivery rake on steel.
I also use it to run an 8 inch by 60 ft auger for corn. If really wet, it opens the governor all the way to the peg...
Growing up, we pulled a 3 section harrow which was a better match in plowed ground.
They are handy things and will run all day on 5 gallons of gas. Wouldn't give mine up for a new one....too simple to work on....
