Re: F12 leaking oil
Posted by JRM on September 27, 2000 at 11:15:31 from (152.163.197.201):
In Reply to: F12 leaking oil posted by Bian on September 27, 2000 at 05:42:20:
The oil leak could be several things, rear main seal, oil pan gasket, or the gasket between the block and bellhousing. The oil pan gaskets tend to move around as you tighten them and I had to put mine in twice. The cork gasket that goes on the back end of the oil pan for my tractor was to long and had to be cut down to fit. Post pictures, I'd appreciate seeing yours. I have mine apart for restoration and need some motivation to finish.
Post A Followup
: Re: Re: F12 leaking oil
