The F would be a number instead of the letter. X1 showes the engine was made to use gasoline fuel. Tractor serial # would have X1 after it if original also. Anyway if the first 2 engine serial numbers are correct the engine came in a last two months of a 48 model or in the first 3 months of 49 model tractor. Need the third number to get closer.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
