Re: 300 engine torque specs
Posted by D Slater on June 02, 2012 at 19:35:54 from (184.15.2.205):
In Reply to: 300 engine torque specs posted by Zachary Hoyt on June 02, 2012 at 18:36:21:
Right on the numbers. Thats oiled threads 30 weight if picky. Oil the pistons, rings, pin and sleeve. For one piston and bearing replacement just oil the parts. Or put some assembly grease on the crank. Don't think you could put to much on the piston pin as most would just push off when putting it in.
Think you had a fircrater piston number in the tractor. 3-5/8 bore one.
