Re: Hydro 656 lost forward
Posted by Bernard le mecano on June 03, 2012 at 08:34:35 from (75.158.242.6):
In Reply to: Re: Hydro 656 lost forward posted by El Toro on June 02, 2012 at 04:03:49:
Hi,the 2 relief valve are pilot type. On the left side of the transmission, it have a rectangular cover with 6, 3/8 bolts. Drain the oil, remove the cover and the center section is here. The forward relief valve is on the left side of the center section, the reverse, on the right side. It have a steel pipe secure to the relief valve, same on the other relief valve. Those pipe goes to the FNR control, then to the foot n inch valve. Check the FNR lever adjustement, if the lever, when in neutral, is not in the center of the cadran, when you engage in forward or reverse, push left or right, the lever close a valve in same time, in the adjustment is not OK, the valve leak and not close the relief valve. Bernard le mecano
Today's Featured Article - Good As New - by Bill Goodwin. In the summer of 1995, my father, Russ Goodwin, and I acquired the 1945 Farmall B that my grandfather used as an overseer on a farm in Waynesboro, Georgia. After my grandfather’s death in 1955, J.P. Rollins, son of the landowner, used the tractor. In the winter 1985, while in his possession the engine block cracked and was unrepairable. He had told my father ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
