Re: IH 3514 loader/backhoe hydrostatic issue
Posted by Allan In NE on June 03, 2012 at 10:26:27 from (148.66.88.254):
In Reply to: IH 3514 loader/backhoe hydrostatic issue posted by Brian Ke on June 01, 2012 at 18:35:10:
Hi Brian,
Pull the hydraulic pump on the right side of the tractor.
You'll see two "plugs" in the upper rear of the opening with pipes attached. The forward check lives under that top plug. Use a 1/2" corse bolt to screw into the check to be able to pull it out.
I'd sure be checking those pipes for cracking tho. The top one is the guy you'd be concerned about for it is the forward pressure feed. Check both ends for cracking.
Allan
