The hydraulics levers are each held on the shaft with a snap ring, there is a medallion on the outside lever that will need to be pried off to get to the first snap ring.
Before taking it apart I would see if this medallion is still available:
p/n 369778R1, or try to remove it without any damage.
after the first snap ring, lever, &washer is removed, it is snap ring ,lever, spacer, washer, on down the line depending on how many valves you have 1, 2, or 3.
I removed my fast hitch from the tractor to prep & paint, so I could get in behind the mounting plates, and all the knooks & crannies on the hitch it self. I did quite a bit of touching up after paint & installation, it's almost impossible to remount without scratching anything, if I had it to do it over again I wouldn't remove it. It's up to you.
This post was edited by rhtx55 at 15:30:00 06/03/12.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
